RetiredDave
- Sep 12, 2020
- 2
- 3
I have a new-to-me 2015 T25i with a little over 1100 hours. The service engine light is on, but is very dim - it is only noticeable at dusk or in similar dim lighting conditions. I checked the ECU codes using the MIL procedure in the engine manual, but there are no codes. Is it normal for this light to be on but very dim all the time? Thanks.
