mikechi
- Jun 25, 2026
- 5
I attempted to replace all 3 belts today. When I removed the idler pulley for the lower drive belt a random nut fell out that doesn't fit anything. I bought the mower secondhand and I am wondering if the previous owner was using it as a spacer for the pulley. I don't see any spacer for that pulley in the parts diagram. I put it back together but now it will drive at idle when I put it in gear and it is hard to shift. It seems like it is probably related to that pulley but I don't know. Any suggestions? I did my best to reroute everything the exact way I removed it but that belt was torn. At this point I'm not certain which way is up for the pulley(bearing side or not).
