T 2290
DWSarow
I'm on my 3rd summer.Im really happy with my purchase.I have read here about belt and pulley issues.I have had none,I took off the belt guards,safety in the seat won't let you be in danger.Keeps crap out,hubs run cooler.I check mine with digital temp gun,they run about 110°on a 75°degree day.
Anybody else have any good tips to keep my machine running well
The only thing I've had go wrong on my 2 year old mower is a pully bearing go out. That was covered under warranty. I added 2 1/2" of leg room to my seat. Now I don't bang my knees on the steering wheel. Disconnected the seat switch and the KRA switch too. I change oil every 50 hrs. with synthetic oil and a quality oil filter.
I hope you don't have any hills because it will slip on those depending on how much you weigh. I weigh 225lbs and it slips even after the new belt was put on. Maybe there is some other inherent issue with my tractor. I disengage the PTO and just go up the hill and mow down. It's disgusting
