Mobil 1 - 10 W 30 is what I plan to use when my 8 hour break in time is up.
The dealer suggested a straight 30 weight petroleum base once the break in time is up, but when I queried him about using a synthetic oil he said that would be a good choice also. He again recommended a straight 30 weight, but there's a problem. Synthetic oil doesn't come in a straight 30 weight. At least Mobil 1 doesn't as I actually called them to confirm this and yes, that's the case - no straight 30 weight in Mobil 1 synthetic.
The dealer said that 10 W 30 would be fine, but looking at a recommended oil for various temperatures chart (regarding outside temperatures) exceeding 95 or so degrees and over - the recommendation shows 40 weight.
So, what do you guys think?
Thanks!
Thanks!
