i have two 5 hp motors one on the tiller i have is bad the other one i have on a other tiller is good but the body on the other tiller is shot both motors are briggs and the only differnce is one has a longer shaft for the pulley. can i switch out the cranks so i can use the other motor on other tiller in stead of buying a crank shaft. would these crank shafts switch out.
