Swisher XZT60 Blowing Fuses
Daisy@25
Swisher XZT 60, 25 horse, model-ZT2560 serial- L106-103106
My Swisher keeps blowing fuses every time I turn the ignition switch to start it they blow immediately. I have replaced the solenoid, ignition switch and chased all the wiring. I can't see any wires that are bad or misplaced. The battery is right as well.
Russ2251
If everyone on here posted the same question 3 times...:thumbdown:
Did you test every safety switch and PTO switch? How did you test the wiring harness? Finding a dead short to ground can take hours on today’s equipment even with a wiring schematic. Even longer without. Need a good VOM, a couple of different jump leads, an understanding of how the different switches work, (some are NC and others NO and some use relays) plus a good assistant.
