Swisher 60 inch pull mower
Calvin
I have a crazy question, can I pull my Swisher 60 inch cut mower 4 wheel backwards to cut? In other words will it mow ok if I wanted to push it instead of pulling it?
Any help will be appreciated.
Calvin.
hitmanharleyk
I'd think you would need to push it in the same direction as you pull it, engineered to mow best that way.
Is a thought though, I'd like to seen one with a bracket made to be pushed by a ATV/Golf Cart/
EngineMan
Would'nt make any difference pushing or pulling it, but why would you want to..?
