Craftsman Garage
- May 2, 2021
- 44
- 561
As you know, I’ve been trying to replace the blown Honda gxv670 in my hustler super z mini. I found a good Briggs and Stratton 24HP vtwin with less than 100 hours for $170 and I’m trying to adapt it to work. One of the problems is this is my first ztr that I’ve worked on and there are relays for just about everything. The old Honda had no regulator, just 2 AC wires going to the built in hustler rectifier/regulator. However, my Briggs has a rectifier/regulator on the side, and a DC charging wire coming off the engine. Do I just not use the hustler rectifier, or do I find a way to wire in the DC Briggs wire??? I have 2 purple wires joined on an eyelet connector, an orange bullet connector, a brown bullet connector, a red wire with a black tracer, and the 2 gray wires with a purple tracer. I also need to add a typical starter solenoid. Anyone got some good info?
