GeriatricGinger
- Jul 4, 2020
- 1
- 1
Good morning!
I've read through the manual, but this seems to have been an issue with the last 3 mowers I've owned (old Huskee 54", Husqvarna YTH-2448, and this Super LT1554) where if I try to lower the deck any lower than the highest setting, it wants to scalp the grass.
With this 1554, I've replaced the deck wheels, blades, belts, greased spindles, replaced hydro drive belt, deck belt, new front/rear tires, changed Hydro fluid, etc. I bought it for $200 with a bad Kohler 27hp. Yanked it, and stuck a 25hp B&S that came with it. Runs like a champ..
The deck wheels are in the lowest hole-set, making the deck ride at its highest possible setting when sat on the lowest selector setting. Problem is, I cannot mow with any lower than a level of 6, or else it scalps/cuts the grass very, very short; oddly, the previous 2 mowers did this, as well).
I can get pictures, if you'd like. But if I R&R the deck, putting the belt on the pulley, then sliding the deck backward to lock the front mount, the deck is really hard to line up with the lifting bars. I have to really pull the deck backward and lift it a little to get the spring pins to line up. I'm guessing maybe the front U-mount make need extended some? Also, the belt is quite loose with the deck all the way up, but gets fairly snug when I lower the deck. Which is another issue I see with mowing in Setting 6, is that the belt tends to slip a bit on the crank pulley..
Any suggestions?
Thanks in advance!
/GG
Any suggestions?
Thanks in advance!
/GG
