sunstar 20 kohler mag 20 pto clutch removal
buckeye_guy
oil seal is leaking behind the pto clutch assembly . any good videos or advice to remove pulley and clutch assembly? do I need a puller of some sort thanks
Normally when you remove the bolt holding it in the PTO drops to the ground. The pulleys sometimes come off easy other times need a puller.
