Hi all. Decided to grease the spindles on my '99 Murray with the 17hp BS Twin II. Had the front end raised with the Mojack. After I put it back on the ground the mower refuses to run. It will start but not build speed and seems to choke down and quit. Saw puffs of black smoke out the exhaust.
Tried to start with the choke and no choke, doesn't seem to make any difference. Sprayed a little carb cleaner down the carb throat and it briefly seemed like it was going to spin up but quit again. Why would all of a sudden seem to be not getting gas after running perfect beforehand?
I pushed it back into the shed and put the battery tender on it overnight. I might try changing plugs and fuel filter on it today if I don't hear anything otherwise. Thanks for any advice.
