Deere Z425 mower. Is there a lift available to raise the mower by the wheels to get underneath other than a floor jack and jackstands? I've seen the one for lawn tractors that raise either axle Something that goes 2-3 feetg off the ground..
There are a few options ( Brands) that will work. I have a MoJack Hydraulic lift that works nicely. Only complaint is it takes a lot of pumping to get to the higher lifting point. I have seen similar jacks that have a screw drive instead of a hydraulic jack. You can use a electric drill to do the lifting and lowering which would be much easier.Deere Z425 mower. Is there a lift available to raise the mower by the wheels to get underneath other than a floor jack and jackstands? I've seen the one for lawn tractors that raise either axle Something that goes 2-3 feetg off the ground..
Are you looking for something that will lift the entire machine.?Deere Z425 mower. Is there a lift available to raise the mower by the wheels to get underneath other than a floor jack and jackstands? I've seen the one for lawn tractors that raise either axle Something that goes 2-3 feetg off the ground..
