Hello,
I have a Subaru engine which only runs with the choke nearly full on (80-90%). The carburetor is a Mikuni, very similar to the one shown here: http://outdoorpowerinfo.com/repairs/subaru_robin_mikuni_27x-623xx-xx_carb.asp
The site above does a nice job identifying the different parts of the carb for me. I'm new to working on small engines (engines of any size, actually). I've taken the carb off and sprayed with a cleaner which made the carb look much nicer but has not noticeably effected how it performs. I'm thinking of taking it to a small engine shop to have it soaked overnight. I'm posting to ask if it makes any sense to try turning some of or all of the screws to try to improve the performance, before soaking.
I read Sheryle's post "off brand" where a two cleanings, a full disassembly and custom-made gaskets solved a similar problem. I've only seen instruction on removing the float on this carb and am cautious to try disassembling it completely, seeing that replacement carbs are approx. $100 and the engine does run with this one. Not so certain I wouldn't damage something to the point the carb is no longer functional if I set out trying to completely disassemble it (that and I'd rather have a full understanding of what each screw, hole, jet, etc does first).
Thanks for any assistance!
Dave
Dave
