STX 38 starting
DonJDart
So far I've changed the ignition switch, PTO switch and solenoid - all brand new. The starter checks out ok. Turn the key and nothing happens. If I turn the key on and place a screwdriver across solenoid bolts it starts right up and runs perfect. I don't know what to look at next?
Serial number please as there are three different wiring schematics for the STX38.
two merge images but this is the wiring schematic. Second image show the cranking circuit. Now the Brake/Clutch must be fully depressed IE ON position for starting.
