spinningwood
- Sep 11, 2019
- 1
- 7
John Deere D110 with 19hp 540cc single cylinder B&G engine. MIA12859 Model Year 2015 Engine Family FBSXS.5402VL
240 hours on the run clock.
Head gasket replaced and valves adjusted at 100 hours.
Starts with no problem.
Idles perfectly.
Runs full throttle with the blades engaged with no problems.
Run it at full throttle without blades engaged, just driving around and the engine starts to stumble badly. No backfires. No smoke. Just periodic pulsing loss of power.
I've changed air filter, plug, fuel filter and oil/filter. Oil level is mid fill. No obstructions (or oil) in the vacuum line from the oil fill tube to the fuel pump.
Fuel pump is working (didn't measure volume pumped, but it was a good flow).
Carburetor solenoid tests good.
The little spring on the governor linkage is intact.
Fuel in tank is fresh (I've run 3 tankfuls of fresh fuel with no change in the situation).
I've now reached the point where I have to ask for help because I don't know what else I can try next to solve the problem. Any and all suggestions welcome. I really want to solve this myself rather than having to take it somewhere for service.
Ed
Idles perfectly.
Ed
