tcanderson
- Jul 1, 2013
- 1
- 1
I think my yard machine is a 1990.
The model #is 136L667F118
It seems like the brake is stuck. If I put it in gear it stops all belts from turning including the blades. Take it of gear and everything turns again. You can't push it in neutral or with the clutch in or both. When I jacked up the rear end I turn the wheels, but they turn in opposite directions. Please help me if you know what's going on.
Thank You.
Thank You.
