I have a small mower with a 4.5 hp Tecumseh that has been hard to start for a couple seasons. Last week it ran for most of the yard and then wouldn't restart when I stopped it for fuel. I cleaned the carb running fine wire through all the little holes and the nut on the bowl. I also cleaned out the fuel tank and the screen is clean and the fuel line is good. After all these years I was amazed that the bowl had no debris in it when I removed it. It had gas when I removed the bowl screw. I read online and many said that replacing the carb cured their problem. I also was skeptical of the ignition. So I bought the carb that had the best reviews, the ignition that had the best reviews and a new correct plug. I replaced the air filter a while back and blew it out. Set the ignition with a feeler that fit the old one before I removed it.
Most said their mower started with one pull with the new carb. Not mine. It finally started and ran for a half minute and then slowed down and stopped just like with the old carb. Won't restart. Gas in bowl. It acts like it runs out of gas but everything is new or clean.
Any ideas? The carb has no adjustments except for the idle screw.
Tom
Tom
