Stihl Trimmer runs slow FS 38
edgenet
Hi All
I have a Stilhl Trimmer FS-38 that runs very slow, I installed a new carb kit No Change The adjusting screws on the carb do not seem to make much difference in engine speed. Any Ideas. Thanks
Does the trimmer have a spark arrestor screen in the muffler. It may be clogged, which prevents exhaust from getting out, and effects engine speed. If it does remove the screen and clean, then replace, or just throw it away.
edgenet
yes it does I had to remove the screen looked like a fuel filter inside a lawnboy carb (what was stihl thinking) It now works like new. Thank-You
