I'm working on a ht101 sthil 4mix pole saw it want RPM up when you pull trigger it cranks and idles but that all but after it runs about minute it will start to rpm up some if you hold trigger wide open, I have change plug adjusted valves clean carb and than tried new carb try it with muffler off fuel fliter is clean,got and ideas?
