Stihl hl75 long reach hedge trimmer blades not moving
chris1682
Hi all
The blades have stopped moving so inspected the gearhead and all seems fine. If I manually turn the gears using a screwdriver the blades move ok.
So to does the metal rod shaft when the engines running, it moves freely without the gearhead attached , so in otherwords under load the blades don't move but do when removed, would this indicate a worn clutch or am I a million miles off? Any help would be appreciated
Many thanks
