stihl hedgecutter needs 17 pumps to start
toecramp
hi
my stihl hedgcutter needs 17 pumps to start, i guess its the fuel pump, or filter, but all looks fine,any ideas
toecramp
Fish
The bulb is not a primer, it doesn't squirt fuel into the engine, but purges air out of the carb itself, so 2 or 3 pumps is all you need, then you put it on choke with the throttle trigger set and pull it until it hits, then take it off choke and pull until it starts.
You might want to start with fresh fuel mix, old fuel these days is one of the major problems with small equipment, and it's
formulation changes with the season as well for easier starting.
toecramp
i know how a hedge cutter works and how to start one, thats my job, for 23 years, but this one will not start without at least 17 pumps, so there must be a reason for this.id say either fuel is not getting into the carb in sufficent amounts or too much air in the carb, so maybe air filter, ive not looked at it,at all,
Fish
Air filter?
Choke would be a more likely trouble area, or if the hedgetrimmer is 23 years old, might need to check the compression.
Fish
Or by 17 pumps, do you mean pulling the rope 17 times?
toecramp
Air filter?
the hedge cutter is an HS ,it snot old, maybe 7 years oldish, ive been doing this job for 23 years lol.
i once looked at a car for a mate, which was back firing, i checked the air filter first, and found 'no' airfiter fitted, the problem
this hedgecutter i bought cheap because of its problems, and i havent checked the air filter, maybe their isnt one,
hmmm
ill check the choke as well cheers mate
Fish
hmmm
I am guessing on your exact model, but it should be similar anyway. but #4 choke lever gets worn where it connects with #5,6,
and will not let the choke fully "snap" closed, but taking off the air filter you can see this readily.
Fish
no i mean pressing the rubber primer, obviously,
Well, you never know. I had a couple of nephews that grew up over there, and when they would come here to visit, they would
giggle when anyone mentioned my uncle "Willy"... And cookies were "biscuits".
RobertBrown
Why would you want a car for a mate?
