Stihl FS46 weed trimmer throttle
Kevin970
Hey all,
I have a Stihl FS 46 trimmer and am have an issue with the throttle. No matter what adjustment is made, the linkage won't let the throttle rest on the screw that adjusts idle. It is holding the throttle part way open. Has anyone seen this on these models? Doesn't seem like replacing the cable would help as it seems like the plastic part that holds the cable by the carb is not letting it rest all the way down.
Are you adjusting this screw.
Kevin970
There in lies the problem. Even with the screw taken all the way out, it doesn't let it rest on the idle adjustment screw. Screwed all the way clockwise is wide open throttle.
I got it. It was the spot inside the handle that was in the wrong spot
