trini_fella
- Sep 10, 2012
- 1
- 3
Hi guys, i've recently started using my dad's Stihl which he owned for like some 8 years but never used.
First question, should i use a 40:1 or 50:1 ratio?? I've looked through alot of manuals for other trimmers and I see most of the older model like the FS 160 n 180 (which I think might be the closest to mine) use a 40:1 ratio. The newer ones specify a 50:1. I can't seem to locate my manual anywhere online and it doesn't even have it listed to order (guess i really have a dinosaur on my hands).
Secondly, and much more importantly, I've been noticing a problem when revving the machine. When I pull the throttle all the way in, instead of revving up right away, it stalls and takes about 10 seconds before the engine fires right up to max speed. Changed the filter and the spark plug recently but that's about it. It really makes using the machine impossible right now. I really need some help. Thx in advance
