stiga park pro problem
seanmurf
HI can any one help
I have a stiga park pro I bought last year and every time I try and start it it runs but blows the main fuse so I cannot use the cutting deck or anything else I have changed the starter motor for a brand new one and the same thing happens it a real pain as you have to remove the big plastic cover all the time. also I have to jump start it even with a healthy battery does anybody have any ideas as im really stuck there is no damaged wiring or exposed wiring everything works fine until you start it as soon as it starts up the main fuse blows engine keeps running but you cannot use the electric cutting any suggestions really appreciated
regards
sean murf
Briana
Welcome to LawnWorld!
We moved your thread to the Small Engine & Mower Repair forum.
