Hi all, just want to say I love these forum sites, lots of good people pot there with lots of knowledge..
Well, I have a sthm with around 1000 hours on it. It has a cvs23 Kolher engine.. The mice got to the spark plug wires earlier this summer and I spliced the wires, not wanting to replace the entire magnetos AGAIN. Anyway, I put a new battery in it at the beginning of summer and a couple weeks later it was dead. I jumped it but the battery never really held a full charge after that. I jump it ever time now.
Today I went to cut the lawn and had a hard time starting the mower. After getting it going I got out to the front lawn and when I went to power up, the engine was misfiring. It appeared that the temp fix of the damaged plug wire had come undone. So I took the top engine cover off and did a better temp fix of the wire and she started right up and sounded great. So I put it all back together and drove out onto the lawn again and when I hit the PTO
switch the engine began stuttering and back firing, like the load was too much. The sound of the engine changed and there was a lot of smoke coming out of the oil breather. I tried this several times at different speeds and I could not get the blades to spin properly or the engine to run smoothly. Then I turned on the PTO and the engine started to die but the pto did not come on. When i turned the switch off the engine back fired and then resumed a normal idle. I did this multiple times and the PTO would not activate and the engine would sound overloaded. I turned the engine off and then started it and tried the PTO again. the PTO would engage but would not let the engine and blades get to proper rpms.
After messing with it a little more I was able to get the blades and engine running at what seemed normal and was able to make several cuts and hen the PTO cut out and he engine died. I restarted the engine and tried the PTO but it would not engage and the engine began stuttering and sounded over loaded.
A month or so ago, my PTO started cutting out while I was mowing and when I checked the wires behind the switch it was so hot that it actually burnt my finger, blister and all. The clip part of he harness that goes to the back of the switch was burnt and slightly melted. I was able to rig it to work and it has done so up until now.
Not sure what's going on, could the dead battery be causing this. I have to jump it ever time now.
