Coelacanth64
- Feb 5, 2015
- 10
- 47
Folks,
My wife mows with a Cub Cadet LTX 1046VT. ( I get the old 1440!)
Well, recently the steering on her rig started to slip. The gears weren’t meshing.
I removed the deck and looked at the pinion and sector gears, and the pinion gear teeth looked a bit worn.
So, I replaced the pinion gear. Seemed all good. I tried it. The steering was exactly tight, but the was no slippage.
Well, she went to mulch leaves yesterday, and after about a half hour the steering was slipping again. Badly.
This am I pulled the deck again and had her turn the steering wheel while I watched the gears.
The new pinion gear now looks just as worn as the one I replaced. And, the gears, for the most part, were slipping past each other.
Now they almost never mesh. Bushing issue??
Thoughts?
Best,
Jack
Thoughts?
Best,
Jack
