Is Poulan Pro covered here or Husqvarna? POULAN PRO 2014, 38" RIDING MOWER, PB145G38, ENGINE B&S MODEL NO 31R607-0005-G1 (585822301) Poulan PB145G38 Engine 14.5HP Briggs & Stratton 499cc 1-cyl gasoline: Will not start at any position on the throttle. Will start if I cover the air intake with my fingers, runs with the air that slips past my fingers, if I spread my fingers any it dies, does not smoke or smell rich. outside air temp 80, humidity 28%, half tank of gas. Had trouble last week, started on full choke after warm up ran at the normal throttle level. Did annual clean and adjust in January, change oil, new plug, exterior cleaned, tank/lines/carb flushed, new fuel filter, new air filter, adjusted coil. Have been mowing since February. Any suggestions?
