Export thread
Starts ok but after warms up starts to stall.
#1
J
joeuser-1
My Craftsman Riding tractor mower has been working fine until yesterday when after mower was running about 5 to 10 minutes it started stalling. Choke would get it to keep running until throttle moved back to run and it would stall. I pushed back to garage and after I was able to restart and it would run like nothing wrong for a couple of minutes till would get heated back up. What could be causing this to start stalling. I checked air filter and cleaned this.
#2
M
Mark1
try loosening the gas cap.maybe the vent is plugged.
#3
reddragon
reddragon
pull the bowl and needle off.....and inspect for rust or ethanol poisoning [yellow gummy or crusty stuff]....you may need to clean the whole thing and get a new fuel filter
#4
J
joeuser-1
:smile:
Thank you Mark1. I took cap off and put back on and did not tighten hard and mower worked again.
Very much appreciate your help.
#5
M
migx
That did the trick.
I too had the same issue, however mine is a Yard Bug I picked up for $100.
Thanks!
#6
T
taxidermist
make sure you clean the vent hole in the cap
Rob
