sdnative1964
- Jul 17, 2012
- 2
- 8
Then motor surges and lopes as if it's a fuel supply problem. Eventually stops running. Gas is fresh and I know flow is fine at least to carb side of fuel filter. Air filter was filthy but does same thing regardless if air filter is on or off. Removed carb bowl and shot float w/ carb cleaner. No change. Removed air filter housing and douched all accessible carb parts w/ carb cleaner spray. No joy. Right now I'm just short of removing carb assy from intake manifold. What typically acts as the fuel pump for these mowers? Is it a mechanically driven diaphragm type pump? Possibly hole in diaphragm? Once motor gets up to normal operating temp it runs pretty well but I still sense a stagger. It's a approx 2007 Toro with a 6.5 HP B&S motor. No primer bulb, but never needed one anyway. Would appreciate any help possible. Thanks.
