I have an old Cub Cadet RZT 50 with a Kawasaki FH661V that I am having problems starting. I have again rebuilt the carb, have spark, and it continues to seem to flood and not be able to start. I checked the compression and it is 90 in both cylinders which seems low to me, but the service manual says anything over 57 ( which seems way way too low!) is fine. I adjusted the valves that were a little too tight. Any suggestions? Should I attempt new rings to up the compression? Thanks.
