iam working on an old cub cadet 143-653-100 16 hrs briggs two cyl.
would not turn over. on the solanoid there is two places one for the starter the other for the battery. there is also another one that usually goes to the switch. but this one hasent any wire going from it.
it also has a ing modual. i jumped the switch to the post on the solanoid and got it to start but i can't get it to shut off unless you pull the plug wire off. i tried shorting out the coils but it still will not shut off. it has thoes diode wires on the coils.
