AshleyBS55
- Sep 14, 2025
- 1
I recently replaced my in-line fuse that runs to the starter. I also replaced the starter. Everything was working fine, then the dash lights were out and nothing worked. I replaced the main 50 amp fuse and it started right up. I drove it on three separate occasions and had no problems. Then it wouldn't start and solenoid didn't click. I then replaced the 5 amp and 15 amp fuses related to the starter. It clicked, the TCM lit up for about a second, then the TCM went out and the solenoid clicked a few seconds later. I checked and the 15 amp fuse was blown. Now the dash lights come on, but I get no click from the solenoid. I checked the starter and thought I found the problem when I saw that I hadn't tightened the "positive" wire (I only call this positive because it has a red rubber cover on it) very well and it was leaning against the wire that connects to the solenoid. I tightened that wire to make sure it wouldn't move and put the red rubber cover on it better. That did nothing. I still get dash lights, but nothing when I turn the key to start. Battery is fully charged. Any help is greatly appreciated.
