Problem started with engine cutting out after 5 min mowing. Restart difficult, but soon found push/pull of ignition key did the trick. Once running, could stall it by nudging key "wrong way." Assumed need to replace ignition switch or loose wire in connector, etc. Yesterday, started engine, but died after 10 seconds or so. Now will not start or even fire. Solenoid, starter, fuse, gas all ok. Pulled & opened up ignition switch: Looks worn, but not sure what it is supposed to look like inside. Which terminals to jumper to check if ignition switch bad? Plug newish, but will replace tomorrow. Need ideas/troubleshooting sequence. Have multimeter, 12V tester, and experienced brain.
