Starter turning slow
bigge31566
I have a 2008 gforce 48" mower with a Kohler 23 hp motor, and when starting mower the starter turns over slow then spins faster and startup, is there anyway to pin point battery or starter
I would start by cleaning the all connections first and making sure they are tight. Don't forget about the ground to chassis, that's the first one I would check.
