starter hitting flywheel
gsale68
i have a 20hp kawasaki engine and the starter is hitting the bottom of the flywheel if you keep rocking the switch it will eventually jump in place and turn over.dont know what the problem is flywheel or starter gear they both look fine.can anybody help
