Thanks Tamo. I found the problem two days ago and your idea was spot on! What I found; the throttle/choke cables run between the filter and block and lay across the top of the oil filter housing. I sat looking at things in general to see if something looked amiss when I spotted the plastic shielding on the cables was melted an inch or so each. A closer look and I found the hard plastic vacuum line had a hole melted through, another spot was so brittle that it separated when I raised it up and all three were laying together. Clearly the pieces against a hot filter housing carrying hot oil wasn't a good idea. The two cables were way too long so I suppose they ran them downward to come out correctly on the engine end. to work. I cut roughly 4" off each cable then re-routed both so they're good and as a temp fix I spliced the vacuum line with rubber hose and re-rerouted it too. This mower has sat outside for a couple of years now but other the stale gas, it started right up and ran great to load it. Ok, so I get fix/modify those things, sat o it, started right up and I took off. And your correct; it's VERY squirrely but this too shall pass. I rode it about 30' and it died, not to start again. Pushed it back to my shop and found the fuel pump was doa. A replacement should be here today and I'll give it another go. This SST is the only one I've seen and never worked on one so I had to read up on the theory of how it works but all in all it isn't too bad. I know SST's were only built only 3 yrs I believe which says something. Wasn't a good idea, maybe?! My in law bought it new and used it until 2 yrs ago and never had problem one out of it beyond routine issues. I certainly appreciate your post/idea and like I said, you were two days late BUT right on as to what to look for so kudos to you! Thx again and have a good one. If u were close by I'd buy you a beer or a coke! :thumbsup:
