Would you please double check the model numbers you posted. I can't seem to find anything with those numbers.
Here's what I can find from the info you posted, going to the Cub Cadet parts site. Your deck assembly number is 190-301-100. The spindle assembly number is 603-0835.
The MTD spindle number you posted 918-04394, has been superseded to a 918-04426. I don't know how you found that number and it may fit your Cub Cadet, I have no way to do a cross reference that number. Don't know if this helps or confuses things.
