Spindle assembly zt20500
cluck024
Hoping someone can tell me an aftermarket replacement for the spindles (arbor housing style) for zt20500.
I can replace the beatings but the housings for the bottom are pretty deformed from being pretty old and they are getting harder and harder to find.
Also wouldnt mind completely swapping decks if at all possible.
Thanks
Bertrrr
I get replacement spindles from Amazon , not sure if they'll list your exact spindle but it will show dimensions and you can figure out if it will work from there, shaft size / length ,pully dimensions etc. Bolt pattern as well
hlw49
They have them on Amazon $38.33
