Speed Feed Head On a Stihl
7394
I love the Speed-Feed head on my Shindaiwa. If anyone is having issue with too sensitive of head that bumps out line too easily. Instead of the washer previously mentioned. I just popped off the end cap on mine & gave the spring a little (very little) spring stretch. Flawless ever since.
Don't know how much line is left ? press the 2 side clips on the end cap & pull it out a bit, you see the line perfectly, no tools needed & can be done in seconds.
And I fill my spool with the recommended 20 foot of .095 line. Which re-load can be done in less than 60 seconds.
My neighbor wants a Speed Feed for his Stihl. His head is always acting up.
