Spark problem
Kmoore
Having problems with a 18.5 hp Briggs and Stratton motor I have no spark coming out of the coil i disconnect the ground wire still nothing I can crank it over and hold on to the spark plug ends I changed the coil and put a new coil on and still absolutely no spark
Scrubcadet10
Moderator
Staff member
do you know what the correct air gap is?
