Snowblower vibration
kenneth2
I have a toro 7-24 snowblower, model #38072 which has major engine vibration at all rpm’s. Disconnected drive and auger belts to rule out issues there but vibration still there. Checked engine mount bolts and they were tight. Also looked at front crankshaft pulley while runnng, no bent crankshaft. Should I pull off engine shroud next and look for loose bolts and or loose flywheel? Thanks for any help.
