Flintmotorsports
I have 3 snow blowers I am I the middle of rebuilding 1 is a older simplicity the other Is a older ariens and the last one
I am rebuilding is a newer craftsman I am rebuilding the motors from top to bottom all new gaskets new rings, new rod and
2 of the motors need new pistons because the piston pin is a different size so that will be a lot easier when doing these units
the only old parts will be the crank and block so a lot less to worry about. one good thing about these units I already got buyers
lined up to buy then and they are not even done.
