Repairs Snapper YZ15334BVE will not start using key
BillW57
I have a snapper yard cruiser that does not start using the key. I tested the ignition switch using an ohm meter. It seems to be fine. I also tested the solenoid which seem to be ok, New battery, new fuse , used a known good relay. I have also checked the seat safety switch so far. I still need to check parking break switch and blade engagement switch. I can start by using a jump box from ground directly to the starter wire. Any suggestions?
