snapper will not pull
OLONKEJEK
I am trying to refurb a older RER.
It will pull in 3 a bit, but pull better in 4 and 5th. (I know this is odd)
The clutch looks like it still has life in it.
please tell me how to measure the height of the metal disk-- that is how far from the bottom of the engine should it be. is that distance from the bottom of the engine to the bottom of the flat plate the sid e of the plate the rubber plate runs on.
I am frustrated at this time, and could use some good advice. I had read somewhere that maybe the spring that holds the clutch assembly to that plate is weak. How do I check it?
Thanks
Dennis Reid
225 Waddell St
Bremen GA 30110
