SuthernBowRush
- May 26, 2011
- 4
I've just rebuilt the carb, got a new airfilter, cleaned the gas tank, etc...on a fairly old Snapper rear engine that I was given. It set up for a while, so its needing work..got it runnin' pretty good..need to tweak the carb a little..but its hard to get to teh carb screws while its running..
Here's the question: where can I find a cut sheet or diagram of the rear axle..w/ all the transaxle parts? The rubber boots are all worn and falling off and the wheels that cause the axle to turn aren't touching...so it won't go in gear..
Any advice from guys who have worked on these Snappers is welcome!! its a SR 1433
