seagiant
- Aug 3, 2013
- 31
- 176
Hi,
I have an older M281019BE Snapper RER.
Trying to get it running again after buying it for cheap.
Figure to go through it and fix what was needed.
Had to replace some shot wiring and stayed with the old Harness and went by the Wiring Schematic, but...
Having problems with 2 of the wires that are killing the spark, grounding out the Coil.
They are the RED Wire from the Module going to ignition ground, and the BLACK Wire from the Pedal Switch to ground.
That is the way I read the Schematic anyway?
There are these "T" symbols inbetween, but assume that is just were connectors were at.
If anyone has any ideas on this I am all ears!
Yes, I have OHMed the wires and the switches and everything test good.
Have also tried each wire seperate and everything fires fine but when either of these wires are connected, no Spark!
![wiring.png wiring.png](https://www.lawnmowerforum.com/data/attachments/58/58153-a722e7535b3056bcb5c56dea87d5157b.jpg)
