Hi everyone! I'm new here but, I can already see that this looks like a great place to get some friendly advice. For this post, please assume that I know absolutely nothing about lawnmowers. Thanks!
I bought an old Snapper RER from a friend recently for dirt cheap. It originally had a 10hp Briggs but, they had replaced that with an 8hp. They also had a 14 hp lying around and I bought that too. I just swapped the engines out but, I don't have a clue how to wire it. The old 8hp had a pull start so, they didn't have anything wired. They just had the throttle hooked up. I'm including the model numbers for the mower and the engine and I can take any pics that might help. Thanks!
Snapper model: M281019BE
Engine model: 287707-0153-01 Code 9211244A
Here's some pics of the wires:
Yeah, I do! Haha. I have a continuity tester already.
That should be the charging circuit. It only puts the charge back in the battery so that's optional for now. Won't effect start or run.1. Yeah, that should be the fourth pic. Should I plug that white wire in with the red and black wire?
Yes. And it might help to mark with tape and labels.2.I'll work on tracing everything now.
It can't say for certain but with those round lugs, it may be to the chassis ground from the Neg term on the battery. Here is where I would take precautions to trace where those go in the cable sleeve. The battery location on this one is different than mine.A. Do you have any idea what the blue/black and red/black wires are in the third pic?
That would need to be traced. Some interlock maybe?B. And what about the plug coming off the back of the engine in the last pic?
Yeah, the small red and small blue plus the long small black wire that's sitting on the tire in the third pic are coming from the switch.
Yes, the ground. Find out where the other wire goes under shroud. If its to the magneto, thats a kill wire, if its to the charging circuit then thats the "white" wire. The charging is optional for now. Keep it simple first.The wires in the last pic are connected to the engine. One wire is connected to the bottom of the carb which is also running onto the block, I guess as a ground. And, the other wire is running under the shroud.
Ok, where should I attach the magneto ground? I traced the blue/black and red/black wires. The blue and red wires go to that plastic box under the seat. The black wire with the red goes to a plug under the engine and the black with the blue goes to a plug under the seat. That wire under the shroud goes to this:
I am not trying to step on Matts excellent advice but I would add Briggs website has a alternator_identification.pdf file you can download which will help identifying what you have as far as the type of alternator and what they wiring might look like from the eng side! It tells you things like if a black wire comes from the stator and has a white connector is ac only and if a red wire it could be 3 amp dc only. I repowered my yardcruiser a few years ago and it was very helpful, I also found wiring diags on the snapper website but I dont know it they still have it for the old stuff now.
Thanks for all the help so far! I'm still feeling kinda lost. I still don't know what to do with the blue/black and red/black wires. Or the wires coming from the mag kill wire and engine block. And what exactly needs to be hooked to the battery? Where do I ground the battery? Sorry for all the newbness guys!
I only have three connections on my solenoid. It has two big posts and a flat connector. Does that change a lot?
I noticed that there's a fuel shutoff solenoid on the carburetor.
To the post on the switch mentioned above which is hot during 'start' and 'run' positions but not while in the 'off' position.So, do I need a new ignition switch? My Lowes has a couple of different ones and they're cheap. What would I look for? And, if I get one, where would that fuel shutoff wire attach?
Hey, I hope everyone had a good Mother's Day with their moms! So, what am I looking for? I know my switch only has three prongs. What else do I need to look for?
OK, so I think i pretty much have everything hooked up now. I went back and studied a diagram from the parts list and figured the extra wires on the mower out. Just to be sure, is the magneto shorting block the plate that the throttle attaches to? I still don't know where to hook the fuel shutoff wires, though. One other thing is that the negative cable is getting hot. I have it bolted to the engine block like the pic shows. The wire is real old. Could that be an issue?
Yeah, I unhooked it immediately! I'm about to head to Lowes and buy a new ground wire. So, what about what cashman said here:
"The engine probably still has the wire harness for the fuel shutoff solenoid and connect to the terminal that is hot in both run and start and not in off position. The kill lead can connect to the "M" terminal or any terminal on the rear of the switch that has continuity to the body of the switch in the off position. The charging lead can connect to any wire that has continuity to the positive post of the battery or the "R" terminal on the rear of the ignition switch."
Is that how I hook up the fuel shutoff?
Update: I got a new negative cable and it helped some. It still wouldn't start though. Well, I went to unhook it but, I tried the key a couple more times. I noticed some smoke coming from the starter. The terminal hooked to it was touching the body and I guess it was grounding. I bent it away from the starter and tried the key again and the engine turned over! Things went south again after that though.
I put some gas in the carb and turned the key and it cranked immediately! It was 5 AM so, I cut it back off. However, the starter wouldn't quit spinning. I tried pulling the plug off the back of the switch and it didn't stop. I removed the negative from the battery but, not before the starter smoked real bad and finally stopped. I've since removed that starter and attached the one from the 8 HP. The one I removed looks like it has a crack on the bottom of it. So, does it sound like the starter was bad?
my carb solenoid has a gray wire that has 12volts when the key is turned on. The other wire is ground.(I think)
The reason for the fuel shut off solenoid is to help reduce an after-boom situation on some applications, in the muffler when the engine is turned off. After the ignition switch is turned off and the engine coasts down to a stop, without the fuel solenoid, raw fuel is still forced through the venturi of the carburetor and ultimately into the muffler where heat from the muffler will cause the raw fuel to explode creating an after-boom. It doesn't shut off fuel between the tank and carburetor. Just between the bowl of carburetor and the venturi. Although having a shut off between the tank and carburetor is still a good idea. If you can locate the wire harness under the shroud that feeds the fuel shut off solenoid, if nothing else, just put a switch between the wire harness and any good source of 12v and be sure to turn it off when not in use. I would try to run it through the wire harness under the shroud because there is probably a diode in that harness that would prevent the reverse flow of 12v that could back feed any other circuits. And be sure to have an inline (30 amp) fuse between the battery and the "B" terminal of the ignition switch and any circuits that are fed 12V as this will protect them from a short and possibly causing a fire.
Thanks for that info. I learned something today. It makes sense. I like to spool the engine down and then do a shutoff.
Matt
