Snapper NZM2152x: parting out near Memphis
Steve83
I bought this (in this condition) just for the drive system & wiring. The rest can go. If you can afford the shipping, I can ship anything. But obviously, pick-up is better for big stuff.
Both rods are sticking through both sides of the block, and the flywheel key sheared, so the 21hp Kawasaki FH641V engine is being parted out, too. Given that damage, I assume the carburetor, coils, & generator are working. Exhaust, flywheel, & various heat shields are also available. No starter or top cover.
The gas tanks are in good condition, and dry now. The selector valve works without leaks.
The fabricated deck is in good shape overall, but the discharge chute is missing, the tensioner pullies don't spin smoothly, and the eng.-deck tensioner arm doesn't move without a prybar. The deck will be sold as a unit, including chains & stabilizer arms. I haven't looked at the blades - I assume they're catastrophes, but the spindles seem to be OK.
The frame & structure seem to be in great condition (virtually no rust or damage, other than the rear shield). I don't really know what stuff is worth right now, so reasonable offers will probably be accepted. As I get things off & clean, I'll add pictures of each part to this post (or thread) so check for edits & updates.
