Hey I have a Snapper with a briggs engine. It is leaking fuel into the oil... any suggestions?
D Dhogeland Forum Newbie Joined Mar 19, 2013 Threads 2 Messages 4 Mar 19, 2013 / Snapper leaking fuel into the block #1 Hey I have a Snapper with a briggs engine. It is leaking fuel into the oil... any suggestions?
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 59 Messages 15,305 Mar 19, 2013 / Snapper leaking fuel into the block #2 Sounds like you need to replace the. Float needle and seat. Common problem with engines using ethanol treated fuel. Simple fix.
D Dhogeland Forum Newbie Joined Mar 19, 2013 Threads 2 Messages 4 Mar 19, 2013 / Snapper leaking fuel into the block #3 Thanks I will try that
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 59 Messages 15,305 Mar 19, 2013 / Snapper leaking fuel into the block #4 Don't forget to change the oil.
D Dhogeland Forum Newbie Joined Mar 19, 2013 Threads 2 Messages 4 Mar 19, 2013 / Snapper leaking fuel into the block #5 LOL you mean the diesel fuel?... That's what it looks like. Thanks again!
