Snapper 7800948
ron815
I have a Snapper push mower and the ground speed handle is hard to push down, especially the last couple of in. I don't want to bend or break anything. Any help would be appreciated. Thanks.
wingless
Chances are the issue is with resistance of the driven disc sliding on the hex shaft.
With the mower off, unclip the short arm from the end of the long shifter arm. Remove the clip and the short arm.
A spring holds the driven disc against the drive disc. Disconnect that spring.
Does the driven disc slide freely along the length of the hex shaft? If not, remove the driven disc and clean the parts. Same also for the shaft in the bracket bore.
IMO, lubrication will just attract dirt, making the problem recur quickly. If lube is used, such as WD-40, for a cleaning agent, then wipe it away at assembly. Mine works fine w/ keeping the parts clean w/o lube.
ron815
Thank you wingless, I'll try your advice. Neither my dealer nor the Snapper people could help me.
